Counter spindle tip
Counter spindle tip
  • Perfect combination of 6-sided complete machining and tailstock function
  • Automatically load and unload a tailstock centre into the chuck of the main spindle or counter spindle via the milling spindle and into the mgazine
  • Support of long and slender workpieces on the main spindle thanks to the synchronous counter spindle tip
  • Higher component accuracy due to automatic change without opening the door (heat flow constant)
  • Position-locking the spindle with the tip leads to increased process safety
User Interface
Left : Automatic changed centering tip. / Right : Parameter Input Mask: Control Cleaning, changing tip and control coolant
Technical data
product-technical data
Machines
CLX*
CTX*
NLX*
CLX TC
CTX TC
CTX TC 4A
NTX*
SPRINT 50 / 65*
NZX*
CTX 4A*
ALX*
Controls
CELOS with SIEMENS
CELOS with MAPPS
● available
